Hello, I am working on a 2000 bobcat 225nt. I have it running and idling fine. The 110 outlets are right where they are supposed to be. I cannot get it to strike an arc. I have checked the fuse on the inside of the machine. I tried to trace wires down but cannot read the numbers on all the wires. All wires look to be attached good. Any help would be great
2000 bobcat 225nt help
Originally posted by benelli7979 View PostHello, I am working on a 2000 bobcat 225nt. I have it running and idling fine. The 110 outlets are right where they are supposed to be. I cannot get it to strike an arc. I have checked the fuse on the inside of the machine. I tried to trace wires down but cannot read the numbers on all the wires. All wires look to be attached good. Any help would be great.
Ok I got 71 dc volts in run and 40 on idle at the studs. I believe that's what cruizer is asking you.
Also check your dials and make sure there snapped in place. Saw a electric Lincoln one day in between 70 and 85 that wouldn't do nothing until we snapped the dial in place.Last edited by Kpack; 03-28-2016, 07:31 PM.
Originally posted by Kpack View PostOk I got 71 dc volts in run and 40 on idle at the studs. I believe that's what cruizer is asking you.
Norm
Originally posted by benelli7979 View PostI wasn't measuring at the + and - studs I was measuring ac voltage at the plugin 110 outlets. I measured dc voltage at the ground and stinger studs and got zero volts
Mind you I'm not a welder tech., but that don't sound good !
Norm
