In .045 what would be the best wire for gasless structural welding. It is a Lincoln ln 25. I just got this and have been doing some research and came up with the nr 211 wire. Need the same strength and characteristics of a 7018 as specs.for are jobs say everything has to be welded with a 70 series rod
Fux core wire?
Ok. I rarely use flux core, I generally use Dual Shield for all my on site welding. In most cases I can get a bottle within 50' or use a small bottle. <br />
But in those rare cases I use Hobart Fabshield 21 or most times just run stick. <br />
Due to the very limited use of it I haven't tried a lot of other brands. So I can't offer much help on this. Sorry <br />
As for my stick, 6010 Lincoln 5-p, <br />
7018 Lincoln Excalibur <br />
Dual Shield I like Hobart Excel Arc 71 but Lincoln also makes a really good dual shield <br />
In shop mig I run Hobart's metal core wire<br />
Good luck Greg
Please define structural? Do you mean just random beams, channels & plates that you get asked to weld or is it jobs with engineered prints that must be done to code? If code work then it should be specified on the dwg.
Nr211 in the .045 dia. is only recommended to weld up to 5/16" thick plate & is not recommended for multi pass work.
Nr212 in the .045 dia. is recommended for up to 3/4" thick plate & also good for multi pass.
I prefer Hobart fab shield 21b in .045 over the above wires. It is also recommended for use up to 3/4" thick plate & also for multi pass work.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
- 1 like
Mostly will be moment welds, tube steel braces, and tube steel lintels for store fronts. This all has to meet building codes and is inspected so yes I need the right wire for the job. Also on the drawings it says to use E70 or better which we use 7018 1/8 or 5/32 depending on what we are welding.
I was told by Lincoln to use 203mp but it only comes in .068 but I have to change the guts in the welder as its set up for .045 so I went to the local supply house and talked with inside sales and he said go with the nr212 so we will see how that works. If the welder does what I want I will switch to the bigger wire on the next roll.
Originally posted by fasthawk View PostAlso I have another ? , is there anyway to hook up a ln25 to a early 90's big 40 gas motor 3 cyl. These do not have all the fancy switches for mig tig ect.
Norm
The older Big 40's had CV option but most didn't hv it installed. It is a smaller panel below main control panel with 5-pin, 14-pin & CC-CV switch. Can't miss it if it has one installed. <br />
The LN-25 can be run CC or CV There is a switch inside the LN-25 for CC or CV <br />
But it is very difficult to weld in CC and the weld quality will not be as good as CV. <br />
LN-25 is designed to be run CV, as most all will advise. <br />
LN-25 very easy to use with any welder. <br />
Connect power feed from welder to rear<br />
Set welder output to CV<br />
Adjust welder voltage to designated voltage <br />
Connect ground lead from welder to work <br />
Connect ground sensor wire LN-25 to work<br />
Set polarity & wire speed on feeder <br />
Hood time <br />
Greg
- 1 like
