Which oil to use in an air cooled engine
    I have see some friends that run rotella t in they 10k dollar street car motors that run in the 10s and never have a bit of problem. If you can run the rotella in a newer 16k diesel truck motor then if should work in a lawn mower motor.
      Originally posted by cruizer View Post
      I read the articles, now does that mean I can run automotive oil in my Diesel. I know, that my engine will soot up and merely blow up. I know that if I run Automotive oil in my $10K Texas chopper engine, that it'll blow up. And I can show you a Cam from a Kohler, run with diesel motor oil all its life, merely pulled as the engine outlived the generator at 12K hours and one at 2200 hrs with Castrol auto oil. Pulled because the engine was simply done.
      So I guess, Rotella diesel motor oil is the way to proceed from now on ?
      Thanks again for your help !
        Alright rotella it is. What wt would be good here in central tx , it's fixing to stay above 95 in a couple of months right now it's 80's in the day.
          Probably 15-40 in a T6 synth Rotella or Delvac diesel rated
            Cruizer;
            In Ontario as well ?
            • #21
              Canada seldom sees 80F constantly so ive been using 10-40 Grand prix castrol or a 5-40 T6 Rotella
              • #22
                Where do you buy these Oils in Edmonton or where ever your shop is ?
                I would prefer Syn. oil can I get it in these ?
                TSC. or Canadian Tire ? or ?????????
                Thanks;
                Norm
                • #23
                  For you, probably best just go to a place that sells semi trucks. Better prices
                  I personally buy in bulk from a distributor
                  • #24
                    OK, hmmm - Semi Trucks. I'll have check that out.
                    Thanks again;
                    Norm
                    • #25
                      I found the 5 - 40 T6 Rotella @ Canadian Tire. $46.00 for 5 Liters.
                      • #26
                        Pretty high compared to a semi place..... But it depends on whats closest to you.
                        • #27
                          Maybe, but it's $10.00 cheaper than the 5W 50 Castrol Syn. oil I have been using since day one in 2012.
                          One other thing I noticed Today when reading the 5W 50, it say that it has High Zinc content ( Castrol Syn.)
                          Norm
                          • #28
                            I put the 5 W 40 T6 Rotella Syn. oil in my welder today & set the Hz. to 44 Hz. in low idle.
                            I'll try the LN-25 tomorrow on low idle to see if it will kick up to high idle when the trigger is pulled .
                            Norm
                            • #29
                              Went to Wally World today and got the t6 rotella it's 5w-40 not 15-40 . It was 23 and change for a gallon.
                              • #30
                                I see the moderators changed the title. They had me try a couple of different ways but nothing worked. I thank them for putting there time in it.
