If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
I was welding the other day with this portable welder moved it and now won't Rev up to make an arc it will kinda spark around like it wants to weld but won't actually make an arc I found a peice of the Rev up part broke but was unsure if it went to the weld part or not it's right below the air filter cover I'm trying to get a pict to load thank you
