I am in the process of repairing some frame cracks in the steering box area on my 1979 C-10 half ton pick up. I would like to get you guys thoughts on how you would approach this repair, specifically that rear lower hole. I plan to end drill and groove out the cracks deep enough to get full penetration to the backside of the frame channel and then stitch & plug weld on one of the preshaped fish plate reinforcement plates. I'll be using a Millermatic 211 with .030 ER70S-6 wire and C25 gas. The hole on the rear lower position is the most challenging and the one I would like to get your thoughts on. The missing piece was not found when I removed the steering box. The small crescent shaped piece is loose. I made a plate to install on the back side of the frame to locate the rear lower hole to the rear upper hole to support things when I repair the crack that runs all the way around the large piece, and I made another plate to locate the 4 hole bolt pattern from the outside of the frame in case I need to redrill any of the holes after repair. I'm thinking I'd repair the long crack that goes around the top, then tack the crescent shaped piece in place. At that point I'm thinking use a hole saw with a pilot that will locate on the hole and remove the material with the crescent shaped piece as well leaving a 7/8 to 1 inch hole. Then install a lathe cut ID, OD and back flange piece into that hole from the back side, groove out around the parting line and weld in trying to achieve full penetration to the back side. At that point my plan was to just build up material weld bead onto weld bead to fill the vacancy where the missing piece was. How would you do this job?
Steering Box Frame Cracks
Originally posted by Whit View PostI am in the process of repairing some frame cracks in the steering box area on my 1979 C-10 half ton pick up. I would like to get you guys thoughts on how you would approach this repair, specifically that rear lower hole. I plan to end drill and groove out the cracks deep enough to get full penetration to the backside of the frame channel and then stitch & plug weld on one of the preshaped fish plate reinforcement plates. I'll be using a Millermatic 211 with .030 ER70S-6 wire and C25 gas. The hole on the rear lower position is the most challenging and the one I would like to get your thoughts on. The missing piece was not found when I removed the steering box. The small crescent shaped piece is loose. I made a plate to install on the back side of the frame to locate the rear lower hole to the rear upper hole to support things when I repair the crack that runs all the way around the large piece, and I made another plate to locate the 4 hole bolt pattern from the outside of the frame in case I need to redrill any of the holes after repair. I'm thinking I'd repair the long crack that goes around the top, then tack the crescent shaped piece in place. At that point I'm thinking use a hole saw with a pilot that will locate on the hole and remove the material with the crescent shaped piece as well leaving a 7/8 to 1 inch hole. Then install a lathe cut ID, OD and back flange piece into that hole from the back side, groove out around the parting line and weld in trying to achieve full penetration to the back side. At that point my plan was to just build up material weld bead onto weld bead to fill the vacancy where the missing piece was. How would you do this job?
Welding in a set of preformed reinforcing doubler plates will help make the repair permanent
http://www.summitracing.com/parts/sm...0/applications
http://www.summitracing.com/search/P...LET/Model/K10/
Very common repair. I've done a bunch of these. Welded it up & then welded on a doubler plate. Used to make them myself before you could buy them.
To answer your question on how would I do it? I would order the reinforcing kit, weld up the frame & grind it flush, then weld on the kit & call it a day. Don't sweat it, just do it. As I said earlier this is very common on Chevy/GMC trucks.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Originally posted by mmw View Postvery common repair. I've done a bunch of these. Welded it up & then welded on a doubler plate. Used to make them myself before you could buy them.
To answer your question on how would i do it? I would order the reinforcing kit, weld up the frame & grind it flush, then weld on the kit & call it a day. Don't sweat it, just do it. As i said earlier this is very common on chevy/gmc trucks.Last edited by H80N; 03-04-2016, 08:36 PM..
