I'm going to look at a used syncrowave 250 in the next day or so, and was wondering if anyone had a sense of going prices. Serial # LB058208 stock # 903765. Seller is asking 3k. There is much still to find out about it.. whats included etc, but it does have the integrated cooler, and a really beat up ol torch. Not sure about gas bottle yet, but i have a few of those.
used syncrowave 250 value
I paid $800 for mine about 5-6 years ago. It was an older model, was filthy, guaranteed to work but I was unable to test it out before the sale. How bad do you need it? It sounds a little expensive to me. They are great machines but are power hungry.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Originally posted by Andrew J 649 View PostI'm going to look at a used syncrowave 250 in the next day or so, and was wondering if anyone had a sense of going prices. Serial # LB058208 stock # 903765. Seller is asking 3k. There is much still to find out about it.. whats included etc, but it does have the integrated cooler, and a really beat up ol torch. Not sure about gas bottle yet, but i have a few of those.
HTH
Griff
Thanks MMW and griff01. It does seem pricy but it looks to be similar to models from the mid to late 1990's, so not too old. So griff01, what's the drawback to the integrated cooler? Another shop near me has a big dynasty 350 with integrated cooler (amazing machine, I've used it quite a bit) and one drawback i can think is that there doesn't seem to be a way to run it without the cooler running. A lot of low amp dc work would be nice to do without running the cooler.
Originally posted by Andrew J 649 View PostThanks MMW and griff01. It does seem pricy but it looks to be similar to models from the mid to late 1990's, so not too old. So griff01, what's the drawback to the integrated cooler? Another shop near me has a big dynasty 350 with integrated cooler (amazing machine, I've used it quite a bit) and one drawback i can think is that there doesn't seem to be a way to run it without the cooler running. A lot of low amp dc work would be nice to do without running the cooler.
Griff
Ha. Well that height issue can't be argued with. I don't share your problem at 5' 9". I get what you mean about the water in the cabinet concept. Its funny you should say that because that same unit i referred to above (the dynasty 350) recently sprung a leak. Its just outside the machine where the torch connects, but seeing that little puddle on the floor kinda makes you think.
That seems very high to me, too. Mine was fully loaded and less than $1000. It's a great machine.
A new Syncrowave 210 is $2750 or so with a free MIG expansion kit. Not sure if that is enough amps, but something to consider before paying that much for a older, used machine.
Burt
_______________________
Miller 211AS
Miller 375
Miller Syncrowave 250
Miller Thunderbolt XL
http://www.10FtDrillBit.com
Could someone tell me, can't get a straight answer from my welding elders, I bought a syncrowave 250, from 2000 - 2001, works great, haven't had it over 200amps, got a great deal on it, Im a small fabricator, and this is a Cadillac compared to the **** Ive had to use/afford prior. Such a good deal, Ive been leary of the purchase, even though it was from a reputable gas/consumables supplier, 45 day warranty just expired. Was runnin it on stick last friday, smelled some hot wires or burning dust inside the machine.
Took it apart, and noticed the fan was not running under load, or that I actually never noticed it running before-over the hum of the water cooler. Ive gotten varying opinions on whether it's fan on demand/thermostat controlled, and that the fan is supposed to be running as soon as the switch is on. Its 2000 -2001. Can anybody say with certainty which one it is ? Appreciate it. GEORGE
Originally posted by georgejhindley.com View PostCould someone tell me, can't get a straight answer from my welding elders, I bought a syncrowave 250, from 2000 - 2001, works great, haven't had it over 200amps, got a great deal on it, Im a small fabricator, and this is a Cadillac compared to the **** Ive had to use/afford prior. Such a good deal, Ive been leary of the purchase, even though it was from a reputable gas/consumables supplier, 45 day warranty just expired. Was runnin it on stick last friday, smelled some hot wires or burning dust inside the machine.
Took it apart, and noticed the fan was not running under load, or that I actually never noticed it running before-over the hum of the water cooler. Ive gotten varying opinions on whether it's fan on demand/thermostat controlled, and that the fan is supposed to be running as soon as the switch is on. Its 2000 -2001. Can anybody say with certainty which one it is ? Appreciate it. GEORGE.
Thanks guys for the opinions on the original topic. Ive got nothing against the sync 210 option (except that i did have an early inverter, maxstar 140 and it died a fairly early death) , i used a 210 not long ago and thought it ran well. But this doesn't help gain a key feature - a water cooler, that I'm really hoping to get along with a used tig. As Im doing more aluminum work now, I'm seeing fewer and fewer routes around the problem. I've seen 3 different syncrowave 250 w under mounted coolers & carts (or "runner packages" i guess they are called) go up on craigslist in the last week each for a minium 3200. I think i need to start looking in a different area. 150 mile radius from nyc is not doing it.
I got a clean but older Sync 250 bare-bones about 5 years back for $850. Couldn't test it but could return it. Worked fine, though the HF went on the blink recently. Maybe have $1,400 into it with a nice used Coolmate 3 and accessories.Miller stuff:
Dialarc 250 (1974)
Syncrowave 250 (1992)
Spot welder (Dayton badged)
Thanks for that USMCPOP. I just picked up a used sync 250 dx with the under mounted cooler, cart, #20 torch, and even a full argon bottle, pedal, and spare helmet. More than i wanted to spend at 3500, but the machine is from 2008 according to the miller serial chart and seems in really good shape. It does't have any of the optional controls.. pulser etc. but i think thats the way the "runner package" comes. A bit off topic, but as for the hours on the machine I'm trying to understand the info that comes up and how to read it. According to the manual, when you start up holding the "amperage" and "output" buttons while powering up the displays will first show the "software number" and "revision" for the first seven seconds, then the arc time and cycle count.
The three images attached show what comes up upon powering on, what is next, and what is after that. I guess that means the software is version 83, the time is 4 hours and 1 minute, and there have been 1863 cycles. Could this be right? Only 4 hours on a machine from 2008?3 PhotosLast edited by Andrew J 649; 03-20-2016, 12:35 PM.
