I am wanting to buy an older sycrowave 250, but will need to bring more power out to the garage to run it. Here are my specs;
The house has 200amps of service to the main panel.
It also has a 150amp off-peak sub-panel which runs the dryer(30a), water heater(30a), baseboard heat(20a) and electric furnace(100a).
The welder location is just under 55 feet of wire length to the main panel, and ran through sch40 outdoor conduit
The syncrowave draws max 92amps at 230volts
I will NOT be using it heavily(150amps MAX), or all that often, before I move to a shop in two months. (Running my first small business)
I also have no issue turing the off-peak panel off, while welding.
I have read other threads of guys claiming they have ran this machine on 50amps for some time with no issue. Others claim this can damage the welder. Since this is pretty much temporary, I want to save $$ on the wiring, but not burn my house down. I have plenty of experience wiring outlets of all sizes, as well as a lot of experience running this machine. I just cannot remember what we ran in the past for this particular machine.
So my two questions are, can I run this welder on 50amps safely, and if so, should I run a 6 or 8 gauge wire?
