I got a new heavy duty milwaukee porta band saw and I'm having trouble cutting straight with it. I'm mostly cutting 1" and 2" lightweight angle iron and square tubing. The cut does well about three fourths through and it seems like the last quarter of the cut is when it tends to drift. Thanks for any advice or tips.
Need help cutting straight with porta band
If all you are cutting I suggest you make yourself a stand and attach the portable saw to that.
It will cut straight with no problem or effort on your part.
I use mine (Makita 1207F) everyday to make small brackets using angle, channel and cut 3 inch OD DOM tubing into 6 inch lengths.
No type of fence or miter head is required either, as the blade tracks in the cut keeping the cut straight. Just draw a straight line and cut it.
Here is a pic I took of mine.
I made the first stand using steel, then gave it to my neighbor and made another one using aluminum. Simple fix for that problem!3 PhotosDynasty 200 DX_set up on 3 phase
Coolmate 3
MM 251 w/ Spoolmatic 30A
HTP 625 Micro Cut Plasma Cutter
Victor O/A Rig
Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
10 inch South Bend Lathe_3 phase
Baldor Double Cup Tool Grinder_3 phase
Baldor 10 inch Buffer
Rockwell 12 inch Disc Sander
Cyclone 2ft X 3ft Bead Blast Cabinet
Quincy 325 2stg- Air Compressor_3 phase
Graymills Built-in Parts Washer
Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
