Miller Legend AEAD 200LE
  • imported_smitty
    understood..........I will skip that step thanks
  • cruizer
    Proper rpm is 62.5 ha high and 44 low, not a good plan to check a control bridge running, unless your real carefull. I zap and its game over for anything down line.
  • imported_smitty
    started a topic Miller Legend AEAD 200LE
    I am looking to test my bridge rectifier. I have checked it with a diode capable meter but would like to test it while running. I had my voltage board repaired and still only have 90 volts ac. The fuse is ok and the rheostat is fine. It is running at the proper rpm and has 60 hertz. I read somewhere a similar problem but found no solution. thanks
