Trailblazer 302 Issues
I will try to flip that handle back and forth and see what happens... Think this will fix issue of the true hours not being displayed?
Flip the start handle back and forth really fast, this will reset the oil change numbers, tank sensor is likely screwed. Easy fix with a jobber or original miller
I recently picked up a "new to me" Trailblazer 302. I have been quite happy with it, however have a few questions regarding some small issues I have discovered.
The first issue, the hour meter does not seem to function, it only reads 1 hour and the oil change reads 99.
The second issue is, the fuel gauge always reads full, however I can clearly see the tank is nearly empty. I am assuming this is as simple as installing a new sending unit. I have heard the tank comes quite easily out of the bottom of the machine. Upon searching for the sending unit part number, it seems to be obsolete. I have found part numbers for other sending units, but I am not sure on the tank depth/size. Where can I find this info?
Also, is it recommended to use any special engine oil? (synthetic, semi synthetic, etc)
Thank you in advance,
ChrisTags: None
