My welder has a very weak arc on both stick and tig . This is an older miller cst 250 the blue light does not flash and it turns on and off normal.
There is 30 volts DC at the output on the tig setting and 60 Volts DC at the output on the stick setting. I have removed the case and there is a little dust but no smoked parts. Everything seems tight that should be . I have read about similar problems but no answers to the fix . I suspect it is the PC1 board but would like to hear what you guys think thanks
