There are plenty of people running large welders like a SYNC 300 on undersized input power sources...
You just have to remember that your maximum output amperage will be limited by your available input amps,,,
So a 300amp welder might only have 150 usable amps...at an undersized input
there are several old threads on the subject
Miller Syncrowave 300, any toughts ???
Doesn't sound like he needs to fix it, just upgrade the electrical service for it.
i'd say pass it. for people who does welding just for hobby or starter, buy a new - cheap weld. you don't wanna wasting time for fixing it before you can use it. except, of you already have one, and need this for its parts.
No other way around it. No magical way to get more power than to upgrade your supply capabilities. I know the feeling, having to do it in my shop for a big old machine I got.Last edited by ryanjones2150; 02-17-2016, 08:22 AM.
Hi!
Seller was supposed to send me some photos of serial #, he never came back or replied to my calls. This is the link to the add: http://m.finn.no/bap/forsale/ad.html?finnkode=69933509
Anyway this one came up for sale: http://m.finn.no/bap/forsale/ad.html?finnkode=70526717 this is about $330.
But it's the the same issue as some of you commented here. The Power intake to my garage/ workshop.
Before you replace the HF high voltage transformer. You need to see if there is 115 vac to the primary side. Do not measure the spark gap side the voltage will kill you meter. I see four problems. HF panel switch bad. Timer pcb. Then transformer or spark gap assembly. Then the HF cap.
Machine is too big for you puny power supply, never the less, the HF problem is the HF transformer. That in itself is not a big problem, costs like $100 bucks.
Originally posted by Olav View PostI will post some photos later, but the biggest issue now is that I don't have more than 36A 380/400V in my workshop. How many amps can it deliver with that input fuse available ? I had a ESAB DTB250 earlier and this also required a big intake fuse. I used this once on 220V 20A welding stainless exhaust for a friends Hotrod. If I'm able to weld 1/4" aluminium I will be happy.
NEED the Serial Number to find the correct docs...
The Serial contains a lot of critical info...
Originally posted by Olav View PostThanks, I will get the serial number. The seller told me that before the HF died it was working occasionally until it died. If he's using as "lift arc" it working perfect.
I found this link to the manual : http://www.westermans.com/downloads/millersyncro300.pdf
Seems like the input fuse is quite big, but no rating for 380/400V.
here
https://www.millerwelds.com/support/manuals-and-parts
HF problems on these old machines are common and usually easy to fix....
there have been many threads on the subject...
Seems like the input fuse is quite big, but no rating for 380/400V.Last edited by Olav; 01-28-2016, 01:21 PM.
Originally posted by Olav View PostI can get a Miller Syncrowave 300 unit complete with torch etc. for $150 here in Norway. The seller say it's working BUT the HF is NOT working. He say it's the internal card thas not working. Is this expensive ? Would it be better to pass on this and look for another unit ? It will only be used for "hobby welding " carparts etc. Any toughts ? Regards Olav
likely it is a simple problem like cleaning and resetting the spark gaps... but first lets get the docs....
pictures of your new prize would be welcome
BTW... sounds like you stole it at $150 (EU?)....Excellent price,,,, would expect to pay 1200-1600 $USD for a fully equipped one in good condition here in the US.... Good Show...Last edited by H80N; 01-28-2016, 08:13 AM.
Welcome, Olav. Looks like your post is missing the word "not". Assume your HF is not working? Keep monitoring the site. Cruizer is "the man" for a question like this and is not always available to respond immediately. And there are others who may be able to help. Activity has been down since Miller revised this site and answers may take a bit longer than they used to. Hope you get it working.
I can get a Miller Syncrowave 300 unit complete with torch etc. for $150 here in Norway. The seller say it's working BUT the HF is NOT working. He say it's the internal card thas not working. Is this expensive ? Would it be better to pass on this and look for another unit ? It will only be used for "hobby welding " carparts etc. Any toughts ? Regards OlavLast edited by Olav; 01-28-2016, 06:40 AM.Tags: None
