Filler rod and tungsten recommendations
  • CaptJeff
    Thanks for the input everyone. I'll take your recommendation and give it a try.
  • H80N
    Originally posted by ryanjones2150 View Post
    309L for sure. Gas lense and 2% lanth tungsten is my vote too. Although I still use thoriated on stainless and carbon steel if I have to swap out sizes or sharpen it, but that's only because I still have a couple packs of the stuff and want to go through it. Otherwise, I use 2% lanth for everything, transformer and inverter machine alike.
    Nice thing about Lanthanated is you can use it for everything... but..
    I still have drawer half full of THORIATED... and may use it up before I am too old... but I do use it for steel ....
    (not for Aluminum. on my inverters. it grows spikes ..... spits and splits on AC..).
    Somebody will scream about the Radioactivity problem inherent with Thoriated.... the threat is overblown. PLS read this
    http://www.diamondground.com/thoriat...-discontinued/
    If you really want to learn the details of Tungsten Electrode selection and prep..... the DG Tung Guidebook will tell you more than you wanted to know..
    http://www.diamondground.com/TungstenGuidebook2013.pdf
  • ryanjones2150
  • H80N
    Originally posted by xryan View Post
    309 filler, any tungsten you got, nice and sharp.
    +1 on the 309,,,, it is the industry standard for welding carbon to stainless
    But I would favor 2% Lanthanated for the Tungsten... just my preference.... on transformer welders 2% Thoriated is still a viable choice....
  • xryan
  • CaptJeff
    Here is the weldment.
  • CaptJeff
    started a topic Filler rod and tungsten recommendations
    I would like recommendations for joining 304 SS 1.25" OD shaft and carbon steel DOM tubing of 1.25" ID. This tubing is a slip fit sleeve 2" long and is welded at both ends. A steel wheel hub is welded to the tubing which spreads the load from the hub over a longer length of the SS shaft. The load that is on the weldment is torsional as well as vertical and operates at a slow 32 RPM's. Currently using ER308L filler with great looking results but beauty is not my primary goal. I would also be interested in any recommendations on tungsten selections too.
    Thanks,
