I am new to the form and I need some help. I have a Millermatic 211. I am using flux core wire and the flux coverage is very spotty and the weld does not look good. I start with the settings on the panel and have adjusted the wire speed and voltage to no avail. What is interesting is the first weld after a cold start with the welder has pretty good coverage. After that, not so good.
flux coverage
Originally posted by lonestar1 View PostI am new to the form and I need some help. I have a Millermatic 211. I am using flux core wire and the flux coverage is very spotty and the weld does not look good. I start with the settings on the panel and have adjusted the wire speed and voltage to no avail. What is interesting is the first weld after a cold start with the welder has pretty good coverage. After that, not so good.sigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
- 1 like
Hope you have changed it..?? from DCEP for gas shielded to DCEN for gasless fluxcore
Wrong polarity will give poor weld bead characteristics
(Jerry... you beat me to it......)
Polarity as said above. You did not say what you are welding? Mild steel I assume? How thick? Is metal prepped & clean? If sheet metal then you may be kind of burning through & sucking contaminants in from the back side. Are you trying to fill a large gap? Same issue. Are you pulsing the trigger (on & off)? This will leave you without enough flux coverage. Wire stick out should be more than welding with gas.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Lonestar
any luck in sorting that out..??.
Could very well be a feed problem. I just found an issue with my Millermatic 211 where the wire does not line up with the grooves in the drive roller. Miller is convinced the motor/shaft is the issue, but I am hoping it is just a mis-machined drive roller. All grooves are off-set about 0.010-0.012", enough that when I swing down the roller arm and slip the tensioner up, the wire ends up still sitting on the flat portion of the roller, and doesn't scoot into the grooves. we'll see.HTP Invertig221 D.V. Water-cooled
HTP Pro Pulse 300 MIG
HTP Pro Pulse 200 MIG x2
HTP Pro Pulse 220 MTS
HTP Microcut 875SC
Originally posted by lonestar1 View PostThanks for the suggestions and I checked them all. No luck in solving the problem. I am convinced it is a wire feed problem, but the Miller repair said no. I sold the welder and am going another route.
Lonestar1
Here are some Fluxcore How-To videos that will answer many questions... for others in the same situation
https://www.youtube.com/watch?v=kI7GOVrB33c
https://www.youtube.com/watch?v=iD7Y57gK3yU
https://www.youtube.com/watch?v=WUYQ87_o_6g
This 1hour Fluxcore Video goes into a bit more depth....
https://www.youtube.com/watch?v=EZDUxZD7GwE
worth the time spent if you are just getting started....
