Help with metal bending
  • Help with metal bending
    Hey guys I’ve been looking at getting a metal bender lately for some auto work and general projects. Would mostly replace the ancient vise, heat and hammer or miter cuts and welding that I use presently use. I looked at HF but don't prefer offshore tools. I found some hydraulic ones, but those are way outside of my price range, especially considering the accessories. Not going to do production stuff at all either. I found these ones http://www.metalbendingtool.com
    Anyone have any "direct" experience with these benders or something else I should use? Looks like they are USA made and have a full warranty which I like.
    Thanks for the help
    I have the offshore one like you posted. Mine is labeled "Realgear" & purchased at my LWS on sale for $79 or $99? I have had it for maybe 10 years & it has done everything they say it will do. Seems to be good quality. I would recommend it. Sorry I have no info on the exact one you posted.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
      If all you plan on bending is flat strap and solid rod, say to make brackets and such, then the $99 offshore bender is going to do the job fine.
      I have a Harbor Freight $99 bender that I have owned/used for the past 10 years and it does what it was designed for.
      Now if you plan to bend tubing you need another type of bender.
      Tube requires you to use dies for the correct diameter tube to prevent flattening the tube as it is bent.
      This type of bender is going to cost you $400 and much higher if you have to buy multiple dies.
      It will cost a small fortune if you require hydraulics for the bender.
      And no...... There are no short cuts here.
      pg
      Dynasty 200 DX_set up on 3 phase
      Coolmate 3
      MM 251 w/ Spoolmatic 30A
      HTP 625 Micro Cut Plasma Cutter
      Victor O/A Rig
      Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
      10 inch South Bend Lathe_3 phase
      Baldor Double Cup Tool Grinder_3 phase
      Baldor 10 inch Buffer
      Rockwell 12 inch Disc Sander
      Cyclone 2ft X 3ft Bead Blast Cabinet
      Quincy 325 2stg- Air Compressor_3 phase
      Graymills Built-in Parts Washer
      Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
        I too have an HF bender at home and at work. Always said you can't wear them out but my work one has had the holes repaired already. Anyways if you have provisions to make one here are some plans. I made 3 of them...Bob http://kinzers.com/don/MachineTools/bender/
          How To Make a Metal-Bending Machine. R.D. Mann.
          Craft Print No 272
          Both these contain good plans and ideas.
            Hi,
            I do not have one of the ones you lined to, do but have a Hossfeld No.2 and a Hossfeld No.1. In the past I had a JD2 bender. The one you link looks like a Hossfeld knock off. It also looks like it has a limited die set which is very big limitation. The cost of there larger units is not all that much less than the more established makes.
            If I was looking for a general metal bender that can do it all, I'd look for a Hossfeld (new or used). If I was looking to do just tubing, the JD2 type bender is a much more convenient design. There are other makes of that design if you do a google search for "Tubing bender".
            Good luck.
              Actually, there are several...
              here is some info of my bender i made last summer. it uses 1" two row chain/sprocket and hydraulic ram to drive the die. power scource is 3 phase 400v 1.5kw motor and hydraulic pump it has hydraulic clamping for tube. first i made the dies or actually cutter to make the dies. pic and vid of...
              I'm getting a rogue fab bender for Christmas and collecting the parts for electric hydraulic instead of using the harbor freight air Cylinder. At work we have a few pumps that I think might work but I know very little about hydraulics. I need help deciding if this pump will work, what diameter...
              home made belt grinder/notcher been making this belt grinder now. im gointo make tube notching attachment to it too. it has 150x2000 (6"x78")belt and it driven dirrect from 3kw motor drive roll is 10" dia front rollers are changeable for tube sizes. it has top sanding place too it has...
              Another HF jack bender design. Now w/ DWG. Not much buggy work today... Decided to build this. My next automation project. One shot 90s, no jack side load. This will be the start of my next automation project. Figured I'd build a manual version then start adding automation. Pretty...
              Walk softly & carry a BIG SIX ! ! !
              MM211 + SM100
                Not a big fan of HF ("horrible freight").
                Occasionally might find some basic stuff that's worthy of service, but generally it's a bunch of crappy junk that has the appearance of shop tools.
                I occasionally use an old DiArco bender, but more often, for 90* bends, I use a custom built "C" frame hydraulic press. This press is little more than some scrap beam sections welded together and a 12ton hydraulic bottle jack pressing two mating 6" heavy angle sections together. Not the best, cheap, but really gets the job done.
                  MSC gave me one to test and gave a write up on it years ago, I make all kinds of things with mine and love it, well worth $ 129.00
