Maxstar 140 220 operation
  • USMCPOP
    People occasionally get banned from the Hobart site by accident. I sent you a private message with an email contact at Hobart.
  • Broccoli1
    The 5-20 receptacle can handle the 240v voltage just fine.
  • chub380
    To better understand it your not running 220v thru your 5-15 Iam running 220 thru my 5-20
  • chub380
    Your not understanding this quite right the plug that came factory on the maxstar 140 is a 5-20 p so I needed a 5-20 style receptical I made the pigtail allready it works great I talked to my electrician friend he said it would be fine the prob I had with it was that a 5-20 receptical is only meant for 115 v if it would be like your dynasty wired for 220 I would have never even had a question I didn't want to cut the 5-20 plug off because I use that for the most of the time thanks ps still not sure what to do about that ban over on Hobart forum
  • Burnt hands
    chub380,
    Here is what I came up for my Dynasty 210 DX.
    Since I have wired all my other 240 volt equipment using 6-50 plugs, I made this adapter to run it on 120 volts for
    the odd jobs where 240 is not available.
    Plug is 5-15 as most of the outlets I come across are not 5-20 type.
    Cost about $20.
ID:	564944 Click image for larger version
Name:	Dynasty 210 Adapter2.jpg
  • chub380
    I ended up making a pigtail from a 30 amp twistlock to a 5-20 female plug to the welder had the twistlock for my table saw not thrilled about the 5-20 plug but after contacting Miller to get a maxstar 150 cord or a 220 maxstar 140 cord with no luck and also contacting fronius with no solutions just decided to do this I welded with it on 220 at almost full output and the primary I put cord didn't even get warm so I suppose it will be ok the 5-20 was a good quality Hubble connector that handled 10 g round wire fine no that that's fixed here's the next prob when I posted this thread about a week ago I also posted basicly an identical thread over a weldtalk as I have been a member over there for prob 10 years now when I log in it said I have been banned for spam and the band will never be lifted what the heck what can I do about this thanks Matt
  • 'Stang
    Originally posted by chub380 View Post
    I realize this is an outdated model but I would like to figure out the easiest way to run this machine on 220v to get a little more output the prob I see is that the plug on the machine is a 5-20 115 v plug this makes it difficult to run this on 220 any suggestions would be greatly appreciated thanks Matt
    I had this problem with my Dynasty. My LWS suggested I go to a local electrical supply. They have the female end that is the mate to the plugs on my Hypertherm PM 30. Wire that up-then just buy the 120-220 male plugs for the Hyperthem! Hope this helps. I like simple!
  • H80N
    I was thinking about that that would be a good option but prob kinda spendy I do still need the option to go to 120 if needed really what I need is a 5-20r style plug rated for 220 then it would be simple another option would be to cut the cord and put on a 6-20 p and go the other way I was sure I remember some guys on here doing some pigtails but not sure thanks for the help so far
    Making a pigtail to switch between 120 & 240 is always an option...a lot of Dynasty 200 owners have done it..
    Here is an old post by Broc that covers it..
    http://www.millerwelds.com/resources...853#post335853
  • chub380
  • H80N
    You could probably purchase the 6.5 ft (2 m) power cord and MVP™ adapter plugs for 120V and 240V that were intended for the Maxstar 150 or MM211 to make it easier to switch between 120 & 240
  • H80N
    Could you post your serial number?? is this an "AUTOLINK" equipped version...?? if so see
    Section 2-12. Installing 230 Volts Ac Input Power Cord
    Page 16 (Page 20 of the PDF)
    https://www.millerwelds.com/files/ow.../O2224_MIL.pdf
  • chub380
    started a topic Maxstar 140 220 operation
