I realize this is an outdated model but I would like to figure out the easiest way to run this machine on 220v to get a little more output the prob I see is that the plug on the machine is a 5-20 115 v plug this makes it difficult to run this on 220 any suggestions would be greatly appreciated thanks Matt
Maxstar 140 220 operation
Originally posted by chub380 View PostI realize this is an outdated model but I would like to figure out the easiest way to run this machine on 220v to get a little more output the prob I see is that the plug on the machine is a 5-20 115 v plug this makes it difficult to run this on 220 any suggestions would be greatly appreciated thanks Matt
Section 2-12. Installing 230 Volts Ac Input Power Cord
Page 16 (Page 20 of the PDF)
https://www.millerwelds.com/files/ow.../O2224_MIL.pdf.
You could probably purchase the 6.5 ft (2 m) power cord and MVP™ adapter plugs for 120V and 240V that were intended for the Maxstar 150 or MM211 to make it easier to switch between 120 & 240.
I was thinking about that that would be a good option but prob kinda spendy I do still need the option to go to 120 if needed really what I need is a 5-20r style plug rated for 220 then it would be simple another option would be to cut the cord and put on a 6-20 p and go the other way I was sure I remember some guys on here doing some pigtails but not sure thanks for the help so far
Originally posted by chub380 View PostI was thinking about that that would be a good option but prob kinda spendy I do still need the option to go to 120 if needed really what I need is a 5-20r style plug rated for 220 then it would be simple another option would be to cut the cord and put on a 6-20 p and go the other way I was sure I remember some guys on here doing some pigtails but not sure thanks for the help so far
Here is an old post by Broc that covers it..
http://www.millerwelds.com/resources...853#post335853
I ended up making a pigtail from a 30 amp twistlock to a 5-20 female plug to the welder had the twistlock for my table saw not thrilled about the 5-20 plug but after contacting Miller to get a maxstar 150 cord or a 220 maxstar 140 cord with no luck and also contacting fronius with no solutions just decided to do this I welded with it on 220 at almost full output and the primary I put cord didn't even get warm so I suppose it will be ok the 5-20 was a good quality Hubble connector that handled 10 g round wire fine no that that's fixed here's the next prob when I posted this thread about a week ago I also posted basicly an identical thread over a weldtalk as I have been a member over there for prob 10 years now when I log in it said I have been banned for spam and the band will never be lifted what the heck what can I do about this thanks Matt
Your not understanding this quite right the plug that came factory on the maxstar 140 is a 5-20 p so I needed a 5-20 style receptical I made the pigtail allready it works great I talked to my electrician friend he said it would be fine the prob I had with it was that a 5-20 receptical is only meant for 115 v if it would be like your dynasty wired for 220 I would have never even had a question I didn't want to cut the 5-20 plug off because I use that for the most of the time thanks ps still not sure what to do about that ban over on Hobart forum
The 5-20 receptacle can handle the 240v voltage just fine.Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
