Hi I have been at a old used 350 mig no pulse. The problem is its 460/575-3ph. Can it be rewired to 220 single phase power ? Or do I need rotary converter and transformer thanks
Miller 350 mig voltage question
Originally posted by mikesystem View PostHi I have been at a old used 350 mig no pulse. The problem is its 460/575-3ph. Can it be rewired to 220 single phase power ? Or do I need rotary converter and transformer thanks
there is a 460/575-3ph only version... pics of the Serial# & Stock# label on the back...???
My own MM350P is the 200/230/460 volt 1 or 3 phase version...Last edited by H80N; 12-10-2015, 12:53 PM..
Originally posted by mikesystem View Posthere what the rear tag says
serial no LH230001B
stock no 907167
volts 460/575
hertz 60
phase kw amp
1 11.4 30/24
3 6 15/12
here is the manual that should match it
https://www.millerwelds.com/files/ow...O1327S_MIL.pdf
Originally posted by mikesystem View Postya thats the down side of it but at least its single phase.
Originally posted by mikesystem View PostI know where there is another one I 350p single phase. What the guy says the aluminum welds are getting dirty and is starting to burn tips any idea what would cause the problems
do full system reset to factory defaults (OM-1327 Page 36 5-8. System Reset)
set the tension as per manual guidelines... CURL..
weld parameter for filler and material being welded...
it's all in the book...
so many times "operator tweaks" have maladjusted these machines... and starting at a known baseline is a good idea...
Which push-pull gun..XR??... 30A??
Originally posted by mikesystem View PostHe said it welds steel fine just not so great on aluminum
Make sure you are Running 100% Argon.. or Ar/He mix for Al....
instead of the C10 or C25 for steelLast edited by H80N; 12-11-2015, 11:54 AM..
