I recently acquired an AEAD 200LE, serial #- JB520789. I want to add a 240 volt receptacle for auxiliary power following the directions “for 120/240 volts ac auxiliary power” found on page 13 of the Miller manual OM-411. If I follow these directions, will the 60 cycle receptacles on the front of the machine still produce power?
Also, page 17, section 5-1 states: “Do not change the position of the Range switch while welding or under load.” Can I change the position while the machine is at idle?
Thanks.
Thanks.
