Hi everyone, I'm new here and have done a search with no results, so now I'm asking for your help. At work we have a Dimension NT450 as stated in the title. The shielding gas stops coming out after about 3 seconds of welding, when on the mig setting. The cylinder is full and the regulator is set to about 25 or so cfm. We are in an enclosed shop so wind is not an issue. The ball inside the flowmeter completely drops and the weld becomes very porous after a few seconds after holding the trigger? Is there a gas solenoid inside the machine that may be causing this problem? Any help would be appreciated. Thanks in advance.
Miller dimension NT450
Maybe a piece of lint/crud/fluff between the gas bottle and the regulator..... not uncommon if somebody was a little sloppy when they changed out the bottle.
I'll have to listen for a solenoid tomorrow. I can hold down the trigger for about 3 secs before gas stops flowing. I can count how long it takes gas to stop and it's the exact same amount of time each time. At first I thought there was a sensor of some sort that would stop the gas from flowing if there was no arc. A coworker noticed it when he was messing with wire speed. But we started running beads, and the gas stops flowing while welding too.
Originally posted by angrybird61 View PostI'll have to listen for a solenoid tomorrow. I can hold down the trigger for about 3 secs before gas stops flowing. I can count how long it takes gas to stop and it's the exact same amount of time each time. At first I thought there was a sensor of some sort that would stop the gas from flowing if there was no arc. A coworker noticed it when he was messing with wire speed. But we started running beads, and the gas stops flowing while welding too.
...........the described symptoms would fit
Originally posted by H80N View PostMaybe a piece of lint/crud/fluff between the gas bottle and the regulator..... not uncommon if somebody was a little sloppy when they changed out the bottleLast edited by H80N; 11-30-2015, 05:58 PM..
Originally posted by ryanjones2150 View PostI'm kind of paranoid about getting crap in the lines. Even if I disconnect the fitting end from the machine, I purge the lines before I reconnect them.
and drove a slug of crud into the regulator...
Learn more about Harris gas regulators on our website: http://www.harrisproductsgroup.comThis video goes through the steps necessary to safely install a regu...
Some of the newer regulators have a sintered bronze filter in the nipple to prevent this type of damage.
I checked for debris, there was none. I also unscrewed the hose from machine and it does get uninterrupted flow. I did notice a clicking from inside the machine when the flow stops. Sounds like a relay or solenoid. An airgas rep is gonna pick up the machine and check it for us. Our boss doesn't want us to open it up for warranty reasons.
