I am building a brake for a 20 ton shop press like this
http://www.swagoffroad.com/20-TON-Pr...-Kit_p_40.html
The punch is made of A36 beveled at 60 degrees included angle with a 3/32 flat. Do any of you have a suggestion of what filler to use if I were to run a small tig pass of filler metal on the flat to prevent wear? I know A36 is soft, but in the above link, that is what they are using. All I have on hand is 309,316 and 308 filler. I can try to get whatever I need. Any suggestions would be great.
