Originally posted by H80N
View Post
Trying to decide which welder to buy, please help me!
As muddled as this has gotten I asked "MillerKevin" about 50HZ operation..... and this was his reply
Sent: Monday, November 30, 2015 10:14 AM
To: Heiti
Subject: RE: NEW MM211 50HZ...??
Heiti,
The New Millermatic 211 is not recommended for operation on 50Hz power..
You will outgrow the diversion quickly. You say you don't weld a lot of aluminum, but once you can weld aluminum, those jobs seem to find their way to your work bench. And it sounds like an ordeal to get this machine to your country, so may as well only do it once. Get something that you can grow into and will be able to take advantage of as your skills improve.
Originally posted by Miller Kevin View Postbpnz,
You will want to go with the Multimatic 200 as it will run fine on 50Hz power, the Millermatic 211 is not recommended for 50Hz power.
Kevin
and it is an inverter- so why does it NOT work on 50Hz?Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Originally posted by pat h View PostCheck ESAB or Lincoln they have machines that fit your needs also.
Originally posted by H80N View PostI would go for separate units, a Millermatic 211 and a Diversion 180 Tig. (maybe step up to Sync 210 or Dynasty 210DX....)
yes the initial investment will be greater... but...
the combination units ar a real compromise in the TIG capabilities... once you experience the versatility of a dedicated full featured TIG machine... you will never go back...
Ad
add heliuk
