deltaweld 452
  • cruizer
    For one thing it's a warranty issue, so best not screw with it internally. Basically being a tech and all, I'd be seeing if the wire can curl in the palm of your hand easily without slipping, cause that's what the problem sounds like. may also be a crap ground / work clamp as the stock ones always are. Best get the brass ones.
  • hillbilly49284
    gun has been changed also.
  • H80N
    Originally posted by hillbilly49284 View Post
    also pulled, blew out, reinserted all plugs on pcb1 in power supply. do not have another power supply of similar vintage to try switching out pcb1 board.
    I meant the MIG Gun "Whip" on the feeder.............. sometimes it is the really simple stuff..that bites you... pretty easy to damage the gun by pulling... on it..
    Have you tried trading out guns for a known good one...??? maybe a bad trigger switch or damaged wiring??
  • hillbilly49284
  • H80N
    yep thats where we started. still under warranty maybe? hoping to fix in house first.
  • hillbilly49284
  • H80N
    working on a deltaweld 452 with s74s wire feeder, both recent models S.N."s start with ME2. operator complaining of cold start, wire not hot on trigger pull. once it does start welds great. sometimes starts fine other times not so well. cleaned all terminals checked all connections everything seems good. any ideas out there?
    Have you pulled the cover... blown it out with compressed air and checked the contactor ...??
    manual
    https://www.millerwelds.com/files/ow...O223BG_MIL.pdf
    parts book..
    https://www.millerwelds.com/files/ow...23Z_PT_MIL.pdf
  • hillbilly49284
    started a topic deltaweld 452
    deltaweld 452
