miller 10e feeder
  • miller 10e feeder
    I have a miller cp-200 with a millermatic 10e feeder. The feeder has started to feed about 3" of wire out after I let off the trigger. Its like the motor coasts to a stop.
    Has anyone else had this problem?
    Thanks
    Thanks
    spool tension... ??? sticky contactor..??
    those are the things that I would check first...
    Serial Numbers...??
      The 10e uses resistors as a brake. One or more are bad.
        What 1997CST said. Resistor R1 - 12W, 10ohm wire wound, Miller PN 030942.
        Also make sure the Normally Closed (NC) contacts in Control Relay 1 (CR1) are making contact when de-energized as these complete the brake circuit.
        Syncrowave 180 SD
        *HF-251D-1
        *WC-1S & Spoolmatic 1
        PakMaster 100XL
        Marquette "Star Jet" 21-110
