Problems welding stainless
    H80N
  • H80N
    FWIW......AWS 5.16 ERTi-5 Titanium TiG Welding rod.... goes for about $85 a pound... give or take....
    Here is a good overview of Ti welding... follow this link
    http://www.cousesteel.com/AndysPlace/TIGWeld.html
    and....Click on "Titanium 101 TIG Welding"
    H80N
  • Goodhand
  • Goodhand
    a remote possibility.....
    I recall a situation several years ago where a fella got a scrap piece of "Stainless".... that he could fuse by autogeneous TIG butt welding.... but it would go VERY bad if he tried to add filler.... drove him crazy....
    Well.... that scrap piece was not stainless after all.... it was Titanium...
    not likely your problem... but anything is possible
    Clever deduction.
  • H80N
  • H80N
    Originally posted by Russellwh View Post
    Well.....after I started looking at the plate, I could make out some markings. AMS-4901B No wonder I could not weld it. This is Titanium.
    Life happens.... it doe look like stainless... a little grayer shine and it weighs a bunch less
    Glad you got it sorted out.....
    so what are ya gonna build with your Ti plate....???
    be aware.... that Ti is MURDER to cut... shape..... bend and form.... .... drive ya coco-puffs...
    H80N
  • Russellwh
  • Russellwh
  • H80N
  • H80N
    Type of machine and settings...???
    sounds like maybe GAS problem.... are you running PURE Argon,,??
    is this possibly a multi-process machine that had been running C25 for steel MIG..??
    H80N
  • ryanjones2150
  • ryanjones2150
    Were you using some sort of packing plate or back shielding? An improperly backed weldment on stainless, especially that thin, will cause you all sorts of problems. Also, try 312 stainless if you don't know the grade of stainless you have.
  • Aeronca41
  • Aeronca41
    http://www.weldingtipsandtricks.com/...ding-rods.html
    Link above to Jody's excellent website has some good suggestions for welding unknown stainless. Good luck!
  • Russellwh
  • Russellwh
    I was trying to weld a butt joint using the filler metal. Lap joint with no filler metal welded just fine.
  • ryanjones2150
  • ryanjones2150
    What type of joint were you attempting when had all those problems? Have any pictures of the trouble?
  • Russellwh
  • Russellwh
    started a topic Problems welding stainless
    I have some 1/16" stainless of unknown type. I tried tig welding it with 309L (all that I had) and it does not weld at all. Lots of porosity and does not even look like a weld. I then set up a lap joint and was able to make a nice weld without using any filler metal. I'm not a stainless welder but I sure would like to use this material. Any ideas of what filler metal I should try next?
    Russellwh
