Thinking about getting that miller 211 with the Spool mate 150, but impulse bought a batch 18x 1lb rolls of 3/64 ER5356 wires instead. Now when I check the specs... the spool gun only handles .035 size and Not sure if the miller 211 machine it self will be able to have enough power to weld 3/64 inch diameter ER5356? Or is it ok to use it?
will the miller 211 able to weld 3/64 ER5356 ?
Originally posted by ryanjones2150 View Postwell...you have now, may as well give a spool a try if it'll feed through the gun. I'm not one to give advice on spool guns since I don't have one, but what do you have to lose? 1lbs of aluminum wire a tip or two?
Originally posted by dogdog View Post
No, I am planning to get the miller 211 very soon, I am using the Lincoln SP135T right now. Asking if anyone with the Miller 211 can tell if the machine have enought poower to handle 3/64 alumninum ER5356 wires and the drive roller etc... the Spoolmate 150 they recommend says up to .035... but not sure.....
just surmising.... best guess... but heck.. give it a try.....
Originally posted by ryanjones2150 View PostI have an old MM250 (I guess that's comparable to the 252?) and I can throw some 3/64 5356 down without a spoolgun like a bad dog. Now I modified my whip and made it much shorter, but it works **** good. As far as a spoolgun that can throw wire than big....I have no clue, never used one.
https://www.millerwelds.com/en/equip...illermatic-252
https://www.millerwelds.com/accessor...push-pull-guns
I certainly have no argument with the 252 but before you spend that much money on a welding machine to use up 18 lbs. of wire, what are you planning to weld? Is 3/64" ER5356 the appropriate wire for the job? If you can afford that machine and spool gun, I say , go for it. Just be aware that you may end up buying different wire depending on what you want to do anyway. ---Meltedmetal---Meltedmetal
