Here is my tale of woe. First my equipment, Trailblazer 280 NT connected to a 251D-1 High frequency box and a PC300 pulser. Right now only the Trailblazer and the 251D are connected in the set up. Oh, I'm also using a foot pedal and pure tungsten rod. All has been fine with this set up until the other day. For some reason when I try to weld aluminum all I get is black, burnt craters. I do have gas flowing and I'm using argon. I've managed to destroy one cup. I've noticed that I have what appears to be little pieces of tungsten flying off the torch when trying to get the puddle going. Frequency on the 251D is on continuous, all switches are on the square with the 14 and intensity I've varied from 0-100 with no change.
I did have the PC300 hooked up to this set up to see if it worked and how well it worked with some trials. Not sure if if works or not. Run on AC and did not notice any pulse when set at 1 p/sec. To be honest this part is all new to me. You ask why the pulser, looking for pulse capability without spending money on new machine. I'm not a full time welder although I have taken courses on it and have welded on and off over the years for various projects I've done. So I'm not a novice and not an expert.
As a side note when set up on DC everything is fine even with the torch still connected to the box with the high freq turned off. I have tried it with continuous and with start and that seems to be working fine base on how much easier the arc starts using high freq.
Thoughts, suggestions or something.
Thanks in advance.
Mike
Thanks in advance.
Mike
