I need some advice on welding a solid round stock to a flat piece of tubing. Whether it be , making tabs , drilling through , sliding the bar through and welding ? Just running welds against the two etc. I'm needing to fix a broken piece of gym equipment again. In the pictures, The square tubing needs to sit on top of the solid round stock . Was just welded poorly and I'd like to re do it extra beefed up. Thanks for any ideas.
Best way to weld round stock to flat ?
Maybe I'm misunderstanding, but your photos don't seem to match what you seem to be asking. The only piece of solid round stock I see is in the first photo, welded end-on to a piece of square tube. Looks like it wasn't welded all around, which I would do if it has to hold up one end of a barbell. I suppose you could drill a hole in the top part of the square tube, to take a longer piece of R.S. which you would still weld all around. But I wouldn't think it necessary. Properly welded by most any ordinary process to the outside of the square tube, you'd have to beat holy heck out of that piece of R.S. with a BFH before it would ever break, ripping out a big chunk of the square tube.
I can't quite see what you're doing with the plate for the shaft (first photo) so can't comment on that.
I didn't really explain that well, sorry. So the 2nd picture ....the bottom shorter piece of square tubing was welded to the top of the solid round stock ( you can see a black line where it was kinda welded to) The rest of picture 2 goes up and has two handles which you push on ( kinda like a bench press) . You can put 240 lbs max on it . This thing should have broke long ago from the original welder way back when . I have the time to try and improve it if it's not way to complicated . For my friends liability purposes, I wanna do it the best I can .
That little ole tac weld was all that was holding the push doofloppy to the round stock? No wonder it broke.
I say grind those black ugly welds out while you're at it too...
Clean off that paint, unbolt those pillow mounts and just weld that sapsucker properly. It's not a piano. Don't over engineer this one.
Ok I can do that . I was looking for a cool way that I could re design it and be proud of it. But I can throw the weld to it and fill it all the way along . The square tubing is kinda thin, but I guess it's lasted long enough so a better weld will last longer . Thanks everyone .
