For one wanting to learn how to do basic stick welds, and figuring they will be using 7018 in the end. Can they start with 7018, and just buy one rod, or should they start with 6011 or 6013?
Practice Rods
Depends on the motive. 13 is widely used by the hometime crowd but rarely in the real welding world. 10 and 11 operate the same so, in the end you need to learn to run 6010 and 7018 and they have 2 different techniques. If you can do this you can learn any of the rest easily and guys that can do this are valuable and there is no faking it.
You can learn 1 at a time, it may be easier.
Sberry has it right. No need for a rod oven for 7018 unless you are doing code work. Either take a course or find a good welder who can show you technique, etc.vs. just practicing on your own. You will be light years ahead that way.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Originally posted by mongobird View PostMy question reworded is: would it be OK to just practice with 7018, even though the technique is different than 6011?
Or is learning 6011 important before one welds with 7018?Bob Wright
- 1 like
