Millermatic 211 will not weld.
  • Millermatic 211 will not weld.
    Hello new here looking for some assistance.
    Milllermatic 211 with MVP.
    Unit turns on but will not weld and no drive motor operation no gas flow valve actuation.
    I have a transformer unit when I turn it on fan runs lights on control panel light up but I pull the trigger and nothing happens.
    I have done the following troubleshooting.
    Trigger switch signal is good all the way to PCB.
    Overheat sensors are good all the way to PCB.
    Spool gun switch good and normally open all the way to PCB.
    Gas valve good ohms but never actuates.
    Drive motor not frozen ohms good. never actuates.
    Rheostats for wire drive speed and amperage control work fine no open spots ohms rise and fall with rotation.
    AUTO weld lamp lights up when set to this position.
    Removed PCB and looked for blown transistors and resistors, back of PCB has no scorched solder joints and is clean and shiny.
    Connectors to PCB from chassis components look fine no wires pulled out/loose. Wiring looms clean and fresh.
    When overheat sensor is disconnected to rectifier chassis, lamp on front panel DOES NOT FLASH.
    Any further advice would be greatly appreciated.
    Thank you in advance.
    T.R
    Cruizer will be the one with the definitive answer when he sees your post but it sounds like you have checked most of the obvious things. Please post a ser no. - that is always necessary for him to help. Also, try calling Miller. They are super to work with. 920-734-9821. Is the machine still under warranty?
      The Serial number is : LK070124N
      Stock number: 907422
      I don't know if its under warranty or not. The unit isn't mine its my son's who is deployed.
      I borrowed it from him.
      Thanks in advance.
        Thanks in advance.
        With n LK070 serial... it would have been made mid 2009 and thus be past warranty..
        View the Miller serial number chart to see when your product was manufactured. Use the serial number and/or the style number to identify the year. Learn more.
        Hopefully Cruizer checks in on this.... he is our resident service/repair wizard....
          "Wizard" is the right moniker for him, as he seems to have quite a bit of technical knowledge. So does Duane. Almost like they've been around a while.
            Bump
              Any luck with Miller?
                I would not exclude "MillerKevin" he is a sharp factory Tech guy
                  T.R
                  May seem like a dumb question.... but have you measured the input power to make sure that you have both legs of the 220 hot..??
                  cycled the power breaker on shop power..??.. or tried another outlet...??
                    make sure the switch is set for the correct gun you are using I had mine on Sppolgun while I was trying to use the regular gun
                    Ed Conley
                    MM252
                    MM211
                    Passport Plus w/Spool Gun
                    TA185
                    Miller 125c Plasma 120v
                    O/A set
                    SO 2020 Bender
                    You can call me Bacchus
                      Right now I'm using it on 110 V and have tried several different outlets at 2 different houses. It wont do anything on either 110 or 230 volts.
                      I also have power cycled the machine several times and the spool gun/WELD switch is in the proper position and has no effect which position I put it into. I also checked it to the Circuit board and it is good all the way to the connector.
                        Have you tried to PM "MILLER KEVIN" ???
                        he is a trained Miller tech who has helped many
                        and may not have seen this thread..
                          Was it plugged in before you borrowed it? Have there been any lightning storms or power outages since the last time your son used it?
                          Walk softly & carry a BIG SIX ! ! !
                          MM211 + SM100
                            TR,
                            With the Auto-set light working we know the board is getting the 24 volt supply and you said you checked the trigger circuit all the way back to the board. I would suggest double checking the trigger leads in the gun cable to make sure neither of them are shorted to the weld cable inside the gun. After you make that check give me a call, PM me or e-mail me directly and we can go from there. Ph: 920-735-4505 e-mail: [email protected]
                            Kevin
                            Kevin Schuh
                            Service Technician
                            Miller Electric Mfg. Co.
                              I,m with Kevin, suggesting that the trigger leads are shorted with the guns internal conduit. This is caused by dragging the machine around with the gun cable. Pretty easy to fix though.
