If you know how to do it safely you can trace it hot with a volt meter. The voltage will disappear right after the problem. Or you can measure across each component and there should not be significant voltage showing except connected in reverse across diodes. Volt meters measure "voltage drop" not really voltage so if you measure the input to the output of a switch for example it should not show voltage even though the switch and power are on. I am speaking about the same lead in and out not across 2 poles. If you use good clip on leads you can connect them with the power OFF briefly turn it on & take your reading and turn the power OFF again before you touch anything to move your test points. Remember you must respect polarity in DC circuits. Watch out for capacitors. You need to discharge them after each power on as they can stay charged and burn your meter out and/or give you a nasty shock which usually causes you to yank your hand or head back and smash it into something else ripping it open and breaking something. Be careful, be safe and good luck.---Meltedmetal
P.S. ONE LAST WARNING: THERE IS EASILY ENOUGH CURRENT THERE TO KILL YOU MANY TIMES OVER PROCEED WITH THE UTMOST CAUTION.
