I have 4 wire motor .The only thing I find wrong voltage on arm should be 20-140vdc I read 26 - 48vdc motor will not turn at all
Millermatic 200 JD663473 no wire feed
If you have not already downloaded the manual... here is the link (Schematics in back)
https://www.millerwelds.com/files/ow...O1303F_MIL.pdf
Have you unplugged and reseated all of the connectors?
checked the brushes and commutator...???Last edited by H80N; 10-20-2015, 11:28 AM..
Originally posted by Thomas Story View PostYes I have only thing left I cn think of is to check cr1 nc contacts to make sure not sticking. Any other suggestions
jumpered the gun switch connector at the front panel with a paper clip..??Last edited by H80N; 10-20-2015, 12:05 PM..
Have you measured for a voltage drop across the contactor contacts while energized...??...
the contactor is a pretty generic motor starter...
http://forum.millerwelds.com/forum/w...actor-sticking
it seems that a large portion of MM200 ills come back to that contactor
Maybe Cruizer or Duane55 have some more ideas..??.
Ok with the crazy voltage reading I was getting. I decided to sand paper cr1 contacts. Turned on machine nothing. Happen to be looking through the different print I had saw + sign on bridge look at mind it was wired wrong. Rewired fired up machine pulled trigger switch wire feed motor started running. Thank for all your help Thank Duane55 for the trouble shooting print
Originally posted by Thomas Story View PostOk with the crazy voltage reading I was getting. I decided to sand paper cr1 contacts. Turned on machine nothing. Happen to be looking through the different print I had saw + sign on bridge look at mind it was wired wrong. Rewired fired up machine pulled trigger switch wire feed motor started running. Thank for all your help Thank Duane55 for the trouble shooting print
Guess I missed the part where Duane checked in.....
Glad you got it sorted out...
Guess I missed the part where Duane checked in....MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
Originally posted by duaneb55 View Post
He was referring to one of my responses to his thread over on WW..
