Millermatic 350 converted to 350p issue
  • Millermatic 350 converted to 350p issue
    Bought a nice Millermatic 350 and converted it to a 350P by adding the Miller pulse board to it (part# 239886)
    Machine runs great with the aluma pro gun until you go to pulse mode then the problems begin. First off not getting any pulse in pulse mode. Second)get bad burn back and melted tip. Third) When I set the machine up in the settings for the aluma pro gun after making an attempt to use it and go back into the settings it shows the gun is set for a Python and not the aluma pro. Since buying this machine (used) with only 115 hrs on it this machine has been setup to run aluminum wire only through the aluma pro. Running 5356 .035 wire. Also can not find in the settings anywhere in the machine after the board upgrade to set the sup value! Does add this board make it pick it up automatically?
    There have been few threads on the subject.... as I recall there were some firmware motherboard issues...
    here is one old thread ....
      I have read several boards where others have successfully converted them over with the simple swap. I was hoping it was that easy but of course it probably isn't lol.
        You might want to post your serial#..... so that Cruizer or some other Miller tech can give you more specific info....
          Did you reset it?
            I will have to post the serial number when I get back home from vacation. I did however reset the machine.
              I really appreciate y'alls help on getting this figured out
                Sorry it's taken me a few days to get back to you guys. Got back from vacation and it's been crazy here at the shop. The serial # LH110219B
