syncrowave 250 no output
  • syncrowave 250 no output
    I've had my old syncrowave for a while. It blew a resistor on the board, ended up replacing it a while back. But now it doesn't even make a spark.
    It does turn on, fan turns on. Hf works.
    Scr's check out good. Transformer has correct voltage. Output selector is good.
    Circuit board looks to be okay.
    I have yet to test the output contactor. Not really sure how to test it with so many wires coming off it.
    I'm not an electrician just a guy with a multimeter.
    Any suggestions on what to test?
    Did it work after you replaced the resistor.... ??
    you my have a hoopd control board....
    Sounds like a case for Cruizer's input....
      Never worked again.
        Never worked again.
        YUP..... Cruizer would be the one to talk to...
        PLS post your serial # ..... he cannot do much without it...
          Serial is. Kh483382
            Gauges do not turn on when machine is on. Tested them and they work
              Board is hooped, quite common. Best to send it out for rebuild
