I'm refreshing in welding haha. Can't figure out why in the @#?* the core in the electrode burns back behind the flux or covering. Making it very difficult to continue to strike a arc. Using 7018 1/8 sticks on regular construction grade steel also some paint on the metal. Would centainly be thankful for the help.
Arc Welding AC/DC Miller
The electrode or "core" always burns faster than the flux.7018 has a fairly stiff flux covering.You may want to try tapping the rod on the work piece to chip away a small portion of the flux.An other option is to break a small piece of the flux off the end of the rod with your`e thumb and forefinger. becareful with the last one as it is possable to get your`e fingers burned.Both these have served me well over the years. Hope this helps.
