Does anybody know of any Miller option that is similar to a Lincoln Multweld 350. If you are not familliar with this unit you can connect it to a powersource via a junction box that many other machines of the same type can be run off of at the same time with no amperage or voltage effect to the other welders running of of the junction box. The user can connect a wire feeder to their Multiweld350 while another welder is running off the same source arc welding, etc.etc
http://www.mylincolnelectric.com/Cat...eet.asp?p=2550
Does Miller have an equivalent system, or are they currentley working on one?
Any help would be great.
Kindest Regards
Kindest Regards
