Hello all, I have a large c-clamp with acme threads. The body is cast Al, and has cracked in half. I have only welded 6061-t6 with my syn 350, with no problem. The material thickness is about 3/4". I need some instruction on prep procedure, filler, and anything else that might help. As always thank you in advance for your expertise.
cast aluminum tig question
Originally posted by rb455hoHello all, I have a large c-clamp with acme threads. The body is cast Al, and has cracked in half. I have only welded 6061-t6 with my syn 350, with no problem. The material thickness is about 3/4". I need some instruction on prep procedure, filler, and anything else that might help. As always thank you in advance for your expertise.
T.J.Miller Dynasty 300DX
HTP MIG 240
HTP 380 Plasma
Bridgeport Milling Machine
South Bend Lathe
Etc. Etc....
tjsperformance.com
cast aluminum has a tendency to absorb contaminants so as you already said make sure you clean the s#$t out of it. If its thicker than 3/4 inch a little preheat with a plumers torch will prove helpfull. you may also want to try one of HAWKS proven meathods of tinning the base, this means welding the surfaces to get any contaminates up to the surface so you can grind them out. Sometimes this takes several tries to get the base clean enough.Trailblazer 302g
coolmate4
hf-251d-1
super s-32p
you can never know enough
dyn88,
You are the man. Tinning takes patience, but sometimes it is the only way to get a weldable surface. I have done several large (15 square feet+) aluminum weldments that were so nasty tinning was the only method that proved effective.
By the way everything is here for the 400 + amp test trial. I sent the tungsten out to KB Fabrications for a precision grinding job so as to eliminate any bad variables. Will be sending info before too long.
Dyn, no problem. Feel free to innerject anytime. I appreciate the information and guidance. I did clean the [email protected]#$ out of it and it is operation as of yesterday afternoon, hasn't broke yet.
