Brazing Silver brazing
brazing covers a few types and many ways to braze.I have done most and have been a certified silver brazer for more than 10 years and love it. I use a gasluxer model 69 that uses a liquid flux that is mixed withe the acetelyene and also do most parts on a turn table fixture as all my silver brazed joints have to have a 1/8" radius almost all parts also have a silver solder ring in a groove on the joining part. 99% of the parts I do are for Navey ships that is the reson for the radius on the joint. it is mor an art as most welding is either you have it or your work harder to get the hang of it. when silver brazing a prepared joing the silver solder ring melts and appears at the top of the joint that is the time to back off on the heat befor adding more filler to make the 1/8" radius.if one holds the heat for 10 to 30 secounds to long the silver solder will drop out of the part and then you have a junk part.
