Hello everyone:
I am new to this forum, although I’ve been reading and enjoying it for a few days now. I would appreciate your helping me decide which MIG welder and plasma cutter to purchase. Please excuse the long post, but I’d like to provide as much information as I think you might want to have.
Intended use -- I plan on using the welder and the cutter for making sculpture (that I eventually hope to sell commercially) during weekends. I doubt I’d weld or cut anything over 3/8”. I expect to work with steel, stainless steel, and perhaps aluminum (I may also cut copper and other metals).
Budget -- about $4,000 (I’ve been saving for a looong time). I contemplate that some of the budget will go towards gas cylinders, consumables, etc.
Space -- rather limited (park two cars in the two-car garage, in addition to storing a Lincoln AC/DC 225A welder, Victor oxy-acetylene welding/cutting outfit and cylinders, a radial arm saw, an air compressor, 2 Craftsman tool chests, 4 storage shelves, a workbench, a pressure washer, 2 floor jacks, a cart for lumber and scrap steel, …. well, you get the idea). I’m considering storing the welder and cutter inside the house and lugging them to the garage when I want to use them.
Electrical supply -- 230V, 30A outlet in my garage that taps into the clothes dryer outlet on the other side of the wall. It ultimately hooks up to a 30A breaker in the main electrical box for the house. Incidentally, to use my Lincoln welder, I calculated backwards (using a rough conversion ratio for the transformer) to conclude that I can safely weld at 135A max. with the 30A electrical supply I have. I suppose I could upgrade the supply, but I haven’t figured out the feasibility and cost of doing so.
Air supply -- I have a Campbell-Hausfeld 125 PSI max., 15-gallon air compressor. It can provide 6.9 SCFM at 40 PSI, and 5.5 SCFM at 90 PSI.
MIG welder -- based on comments on this forum and other forums, I’m considering the Miller Passport 180, although I’m open to comments and suggestions. From some comments, it seems that the Passport does not do well with welding aluminum (if things go well, I may consider buying a TIG welder down the road so I can handle aluminum but, right now, I’m not sure).
Plasma cutter -- I’m considering the Miller Spectrum 625. Reading various posts, however, it seems that many of you either own or recommend other brands. Also, given that the Spectrum 625 seems to require 6 SCFM at 75 PSI, my air compressor may be inadequate or marginal. How sensitive are plasma cutters to having the precise air supply available? (I suppose I could reduce the duty cycle to give the compressor a chance to catch up.)
Merchant -- As the “little guy,” I haven’t had good luck hooking up with a local supplier (the closest metro area is Austin, TX), so I’m considering online merchants. I would appreciate hearing about your experience (recommendations/warnings/price data points).
Thanks very much in advance for your help!
