i have a "source" that says stick welding is stronger than mig, is this true, becuase i always thought that they were about equal, and this "source" also says that stick penetrates deeper, which i also disagree with because you can adjust how far the arc penetrates with the wire speed and voltage...
are my beliefs correct or not?
i also have to complete a job for this person which wants atleast 60000 psi strength in the welds for a truck bed. when ive only got lincoln super arc s-6 which i do not know the tensile strength for but i dont think its 60000??
lincoln says that the superarc LA-75 which is ER80s-Ni7 has a minimum of 80000 pounds tensile strength, but its a low alloy wire... is this ok for mild steel?
i need to use all of this for a truck bed which i have alreayd mentioned is mild steel and im going to do it with .35" so i dont have to adjust my machine much..
and one more question does anybody know if i can run this superarc LA-75 with c-25 gas?
whomever answers these questions thanks alot, it will be really helpful.
farmboy
farmboy
