WELL GUYS IT WAS THE SLIDER WIRE ON THE FOOT PEDAL THAT WAS CAUSING ALL THE INTERMITENT AND WEEK ARC PROBLEMS. I ALSO FOUND THAT THE COIL THAT THE SLIDER CONTACTS IS WEARING OUT ALSO. I HAD A REPAIRMAN COME TO LOOK AT SYNCRO500.SO THE FOOT PEDAL WAS THE CULPRIT. THE WIRE WAS MOSTLY BROKEN INSIDE THE CASING BUT OUTSIDE OF THE FOOT PEDAL BOX. HE(the repairman) SAID IT WAS QUITE COMMON FOR THIS TO HAPPEN. ALSO HE SUGESTED TO PUT A MESH OR COIL CASING AROUND THE WIRE AS IT GOES INTO THE FOOT PEDAL BOX TO PREVENT THIS IN THE FUTURE. IT COST $75.OO AN HOUR FOR TWO HOURS AT THE SHOP AND TWO HOURS TRAVEL TIME. $300. BUCKS TO FIND TWO LOOSE WIRES.
ALL I CAN SAY IS
LIVE AND LEARN.
BUT THANK YOU GUYS FOR YOUR RESPONSE!!!!!!!!!
ALL I CAN SAY IS
LIVE AND LEARN.
