is there any wrong way? I will be repairing 2 2 inch holes in a tube frame. the holes are on the vertical surface. I will be mig welding and repairing with either 3/16 or 1/4 flat stock and putting a 90 bend on the bottom of the plate to wrap around the frame.
Frame repair
Frame repair
Lincoln SP170T
ESAB 875 Plasma
Smith oxy set
pulsed mig is next...
Long Island Cummins Ram Owners ClubTags: None
Clean up as much of the rusty area as possible. Make the repair patch 4X as big as the bad area. Also drill some holes in the (good) steel where the patch is and plug weld from the frame to the patch. While your down there check out the rest of the frame closely. Use the pointed end of a chipping hammer on any and all rust spots you'll probably find more holes. Good luck and be safe!
Bulldog5 Passport Pluses
2 MM 212's
MM 210
MM 251 MIA
MM 350 P w/Python
w/ tig runner
Trailblazer 302
12RC w/meters
Spectrum 1000
Spectrum 2050
2 Black BWEs
Joker BWE
Star & stripe BWE Digital
2 star & stripe xlix's
REAL TRUCKS RATTLE
CUMMINS BABY
I have also been told NOT to weld completely across a frame rail, as in if a frame cracks vertically (similar to a mid-80's Chevy Truck frame at the steering box mount), skip weld the patch. The HAZ area will cause a weakness, and with a continuous weld, will crack across the frame. I have noticed that people tend to make the welded edges go diagonal "down" the frame, to also help spread the loads and HAZ area.
On dove tail trailers, I have seen reinforcement doubler plates added at the dove tail bend. The reinforcement plates were a diamond shape, so the HAZ was not vertical across the load bearing member.
I don't know if this makes sense or even helps at all. Hopefully it does.
Joshua
thanks for the info the diagnal makes sence. I have a nice big chipping hammer i planned on using and was also going to drill the holes in the plate. Ill try to take some pictures.
Is there any pluses or minuses to cutting the rust out and doing a butt weld as compared to laying the plate over the top and lap welding it?Lincoln SP170T
ESAB 875 Plasma
Smith oxy set
As far as cutting out the rusted piece It would depend on how badly the thing is rusted. If the frame has any structural integredy to it at all I think I would cover the bad section and if the frame is totally shot cut it out and put a piece in then fish plate over that.
2 MM 212's
MM 210
MM 251 MIA
MM 350 P w/Python
w/ tig runner
Trailblazer 302
12RC w/meters
Spectrum 1000
Spectrum 2050
2 Black BWEs
Joker BWE
REAL TRUCKS RATTLE
CUMMINS BABY
I would also suggest treating the rust if you are going to cover it up. There are products out like POR-15, Naval Jelly, etc... that you could put on first IF they are away from welding. Maybe this way the rust will slow down, or even stop completely.
What I have done on my car "chassis" (unibody actually, but still rusty) is use a sanding disc to get to bar metal first, then put a patch over. I would say that regardless of what you do, butt weld or not, that you should still put a doubler plate over the affected area, if possible. You may want to even box the frame if it is not boxed already. That will definitely make it stronger and stiffer.
Joshua
Always weld horizontal on a frame repair. Weld the top and bottom of your overlapping plate and make it big enough to put bolts through on both ends of the plate. If your frame has holes already make your plate large enough to use those. If not make your own.
Originally posted by df5152 View Postis there any wrong way? I will be repairing 2 2 inch holes in a tube frame. the holes are on the vertical surface. I will be mig welding and repairing with either 3/16 or 1/4 flat stock and putting a 90 bend on the bottom of the plate to wrap around the frame.
Where I work we use Qt-100 alot for for trailer frames not sure why it's just what the engineers decided to design with I guess. We also bend up Qt-100 rails for the truck shop my boss owns for when they do the odd frame stretch. It's a pain in the *** to bend.Hobart Mega Arc 5040DD (with built in air compressor)
MM Passport Pluswith Q-gun
O/A
sold MM 251
There are only 2 tools needed in a tool box. 1) Duct tape to fix any thing that moves that isn't supposed to. 2) WD40 to fix anything that doesn't move but should.
