AL problem with dynasty 200
  • #31
    grocery_getter,
    Thank you for the update. I am glad to hear there is nothing wrong with your Dynasty! What is the price difference in the pre-purified versus what you were getting in the argon gas?
    • #32
      Way back when this all started, I thought it looked like bad gas.
      Thanks for the update! As you said, it can be a learning experience for everyone not to take for granted that your gas is ok. It may even be ok at the beginning of the bottle and go to **** when the bottle gets down a ways.
      Happy welding!
      Andy
      • #33
        Originally posted by HAWK
        grocery_getter,
        Hawk,
        I am switching supplier from a small local welding shop who get their gas from Liquid Air to Airgas. For those that dont know Airgas pump their own gas. The difference in their buying power netted me a very good deal. I exchanged all 3 of my 155 tank to 3 pre-purified 220 tank for $5 more per tank. Cost of refill is only a couple dollars more. Its a no brainer. I'm doing pre-purified from now on.
        Andre
        I love Miller products
        Spectrum 2050
        Hobart 135
        Syncrowave 180SD (sold)
        • #34
          bad gas, no good
          • #35
            I purchased my Dynasty 200 DX new from EBay, When I got the machine I ran a couple test beads. The weld was Bad. I tried aluminum and was even worst. I called miller and they told me that Weldcraft put out some bad hoses. Something to do with the manufacturing of the hose and some lubricants were braking down and mixing with the argon during welding. They sent me a new hose and now is much better, but the welds on the aluminum still have some small impurities on top of the bead. The welds do not look as shiny as the AC machine one. I'm still testing and plaing with Fric and amp and balace mix
            • #36
              Happy welding!
              Andy
              Not long ago I had a bottle do that very same thing, started out fine but towards the end it was unuseable. There was still acouple hundred psi but was all bad.
              My sincere thanks , Pete.
              Pureox OA
              Westinghouse 300 amp AC stick
              Miller Syncrowave 250
              Hexacon 250 watt solder iron
              • #37
                Unusable in terms of all welding? Or mostly noticeable with aluminum?
                Thermal Arc 185TSW, Lincoln SP135+, 4-post automotive hoist, 2x media blast cabinets, 50 ton press, 80gal air compressor, 4-1/2"x6" bandsaw, 4'x4' Torchmate CNC table with plate marker, Hypertherm Powermax 65 plasma cutter, ultrasonic cleaning stations
                • #38
                  Iv'e never heard of a tank of argon starting out fine then going bad Does it some how seperate????
                  Pete
                  • #39
                    Yes We all hate to get Lumpy gas but it does happen occasionally.
                    Dynasty 200DX With TEC Superflex 9 & 17 Torches,
                    Hypertherm 30A Plasma
                    Rincoln SP130T Mig
                    • #40
                      I STILL, HATE lumpy gas
                      Syncrowave 180 SD
                      MM185 with 3035 Spool gun
                      1971 Roughneck 1e
                      Stars-n-Stripes BWE
                      Optrel Satellite OSE
                      ESAB 875 Plasma Torch
                      Lincoln 200SA Diesel
                      O/A Set
                      Century 250A/C-D/C BuzzBox
                      1.5 kVA Spot Welder
                      Phoenix Electrode Conditioning Oven
                      My own shop since 1981
                      Cya Frank
                      • #41
                        I couldn't weld any thing with it. Drove me nuts becouse up untill then I never heard of bad argon. Even if I had I still would not have expected a good bottle to go bad.
                        Pureox OA
