miller helmet #770413
  • miller helmet #770413
    I'm looking at an autodark helmet that is supposed to be a new miller model #770413.I looked on the miller web site and can't find this model.It looks like the XLi series but the specs dont mach.For example the XLi has a speed of 1/16,000 and the one i'm looking at is 1/20,000.The lens shade is 3.5 light to 9-13 dark.It has a self charging 3-volt lithium battery.I want something for tig welding and would like to now if this would be a good helmet.I cant confirm the info becous I can't find this part # on millers web site.Any information on it would be greatly apriciated.
    To all who contribute to this board.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    the 770 series is the nascar driver series. #770 228 dale E. Jr. #770 252 dale E Sr. #770 254 jeff G. i dont have 770 413 in my 2005 book but ill look in my 2004 it sounds from the specs. you gave you are discribing a XLix series helmit and it would work great for tig as it is rated down to 5Amps and is inverter capable. any chance you copied the # rong ???
    hope this helps
    sigpic
      I just talked with our helmet specialist and he thinks the 770413 is a hobart version of our 217290 helmet. I haven't tried it. Kind of depends on what you are using it for. For TIG welding I would still go for the 4 sensor elite. The tig arc is so small that it's easy to block it with a hand, torch filler metal etc... that the 4 sensors are a big help in not getting flashed.
      hope this helps
      Andy
        It looks like the 217290 so I'm sure its probaly the hobart version.They dont specify the number of sensors but its probably the same as the miller.The price is only $50.00 but I dont want to take chances with my eyes at any cost.They are the only thing I have that still works.I am just a hobby type welder.
        Thanks for the advice.
        Pureox OA
          At 50$ that's definitly a mig or stick only hood.
          a-
            miller BWE
            if it helps any i have the miller BWE and it rocks
            sigpic
              I'm going to pass on this one mostly becous I'm beginning to wounder if the people selling it actually own it.
              Pureox OA
