It's still going pretty good, this is a learning project and I've learned a lot. I definately over welded everything... Next time I will use less wire. On another note, my gas solenoid is sticking on my 350p, if I shut the machine off and turn it back on it will usually stop, what a pain, climb out of the boat , down the ladder, then back up and in. Wasted a lot of argon.
Updated drift boat pics
http://groups.msn.com/ArcAlaskaWelding
mm350P,Trailblazer 301g
Spoolmatic 30A
R115, XR30A, SP32
TD cutmaster 38 plaz
PowCon 300sm w/feeder
Lincoln Hi-Freq
'05 Topkick Crew 4x4 Duramax Edge Juice w/Att 12' bedTags: None
That's awesome!!
But wont all that aluminum suck the heat out of your bum??
You could actually have a solenoid problem. There was a vendor issue not too long ago where they put the wrong springs in the solenoids and they wouldn't shut off. It would leak anytime though and you say that if you turn the unit off and on it's ok?? That sounds like a micro processor hic-up. In either case it's a fairly easy fix. Call the service dept. If you are far away from a service station, they should send the stuff right to you.
Andy
Overwelded? Ha! That's a slick thing you're building there. Bet you everyone who sees it will want to know "What kind of boat is that? Where'd ya get it?".
Hank...from the Gadget Garage
Millermatic 210 w/3035, BWE
Handler 210 w/DP3035
TA185TSW
