I am trying to figure out whether I can safely run a Plasma cutter in my garage. I feel I might not have enough power at the panel, so I would really appreciate some suggestions.
The main breaker is 150A. I have a 20A 220V (table saw, Dynasty, possible plasma with upgrade) and a 50A 220V (air compressor, Ingersoll Rand True 5HP Two Stage). I am looking at the Miller Spectrum 625, and it is rated at 30A 230V. I am considering upgrading the 20A to a 30A circuit anyways for the Dynasty, but don't want to get that done and then need to install a 40 or 50A additional circuit for a plasma.
We have a gas dryer (breaker switched off) and electric stove. I will remove any and all 220V circuits I install when I move, but I want to do this to code if possible. I don't want to swap out panels if I don't have to (Service company says that I have 220A available if I want to upgrade the panel).
I measured one leg of the Air Compressor circuit for current draw, and noticed that it draws ~113A when switching on, then while running is drawing ~26A. My tank is 60 gallon, 175 psi maximum, so while decent size, I expect that while I am using a plasma cutter, the compressor WILL kick on. If I have a Spectrum set to maximum (~30A input draw), and the compressor kicks on, and I going to trip the main breaker? What if the microwave, or worse yet the stove is turned on? Any ideas?
Finally, if I do have to upgrade the panel, does anyone know if I can simply buy the same brand (Siemens) 200A panel and swap only the guts. The walls are finished, and the outer case looks like it has some sort of universal hole pattern. The case itself is really much larger than the buss bars, MUCH larger, like it is universal in size. I am not trying to get out of code requirements, or having it inspected, merely trying to minimize the work to change the panel.
Thanks so much for any input...I really want a plasma but am worried about this power thing.
Joshua
BTW: another rec from a friend was to get another compressor just for the plasma, but then that takes up precious space and money...I would rather not do that.
Joshua
