I have a bottle of mixed gas that is 75% Argon/25% CO2, and was wondering if there is a way to check the actual percentages? I recently purchased a gas mixer and I would like to check the calibration of it by checking its mixing percentages. Can anyone help me.
Gas Mixture
Mike, I opened the mixer's case and look inside, not much. There is a small mixing chamber and two metering valves one for gas mixture and the other is your flow rate. Smith requires a minimum of 55 psi on both gases for it to work properly. So I also had to buy Inert pressure regulators because my flowmeters would not go high enough. I am also looking into building a manifold that would allow me to feed a regulator and a flowmeter off the same bottle at one time.
I have a flow meter that had a bad diaphram. I blocked it off and am just using the flow meter part of it on the output of the mixer. The funny thing is that if I set the flow meter on one of the tanks to say 20 cfh, the other flow meter will read higher. I expected it to read lower because it wouldn't have the correct pressure. There has to be a simple explanation but I haven't found it yet.
Mike, it appears that on the mixer I have they use a fix orifice to control the flow of Argon ( no adjustment ) that is why they require a minimum pressure on both of your input gases but you a can control the amount of CO2 you are mixing by adjusting the metering valve which then passes into the flowmeter.
