i need bending info. pt 2
  • i need bending info. pt 2
    ok, i finally got around to making my new box. this one turned out much better than the original. and i learned much from it.
    its .090 3003, 4"x23". bent around a 1" bar. i figured out the measurements well enough to mark it out flat. bolt it in the jig. and bend it so its only 1/16" out of square, one side is 1/16 narrower than the other. this is nothing for this project. and i could bend the second piece i got, to an even better tollerance. but that would be a waist of time. when i made the last bend, it came to a perfect butt. but i had to overlap it, because the metal stretched about 1/8". and so i could go beyond the bend to make it stay.
    Did you anneal the Al before bending or just bend it cold? Just curious.
      just bent it.
        What is it for an upper intake plenum. If so it looks good so far. I do not think 3003 has a hardness like T-6511 so it should not have to be annealed. You gave me some good ideas for making an intake box for a BBC EFI tunnel ram set up I want to do for my jet boat. I also made an intake box (no bending) for my Eaton Blower project. I used 6061 t-6511 so I could not bend it.
        If you go to my site and click on the 87 mustang blower project you will see what I mean.
        T.J.
        Miller Dynasty 300DX
        HTP MIG 240
        HTP 380 Plasma
        Bridgeport Milling Machine
        South Bend Lathe
        Etc. Etc....
        tjsperformance.com
          S10- very nicely done,
            TJS. welcome to the forum
            yes, its an intake hat. i made one a few years ago. it turned out pretty good, on the outside. but the inside left something to be desired. so i tried to fix it, and ended up screwing it up. so i figured it would be easier to make another.
            maybe this pic can give ya some more ideas. more pics can be found in my "lets see your hot rod" thread.
              oh-yeah. interesting project you got going. wish i had use of a sheer like that
                I realy like how crisp the bends start and stop.Very clean.
                My sincere thanks , Pete.
                Pureox OA
                Westinghouse 300 amp AC stick
                Miller Syncrowave 250
                Hexacon 250 watt solder iron
                  and they really are just that nice. so far i'm really happy with it. i made the base plate, and welded the seem, today.
                    Blown S-10,
                    I am selling that shear. It is just too big. I am moving my shop to a home garage and I need to get a smaller shear. I am going to make an upper intake plenum for a Big BlocK chevy tunnel ram that I am going to convert to EFI. I think I am going bend the corners like you did with that simple JIG. After I convert it to EFI I am going to TWIN TURBO it and it will be the power for my Nordic Jet boat. This is an ongoing project. I have a ****** LS-6 I have to do some work to as well. Great looking engine compartment by the way.
                    T.J.
                    HTP MIG 240
                    HTP 380 Plasma
                    South Bend Lathe
                    Etc. Etc....
                    tjsperformance.com
                      T.J.
                      www.tjsperformance.com
                      You could have brought your T-6511 back to the 0 condition by annealing it in the bend zones....but then you wouldn't have those pretty welds to show...nice work.
                      Arcin' and Sparkin', Rocky D
                      "Experience is the name we give our mistakes"
                        Blown S-10,
                        T.J.
                        i wish i had the room for it ! btw, what are you asking for it, and where is it ?
                        when you are ready to bend. let me know. i will give you some pointers. things are not exactly as they seem when making these bends. thats why its 6x6.1", and not 6x6".
