When they wear out they will be oval or off center instead of nice and round. The cut quality will also go down and it will start cutting at more of an angle than straight.
They will also wear faster if you are dragging all the time at higher amp settings. If you are at the higher amp settings, try a little standoff while cutting.
I just put this nozel in on friday, maybe used it for 40 minutes combined since then and it's already worn out.
I do drag all the time, cant seem to keep a cosistent stand off ( too shakey )
