Just curious, I think I read a while back about the 210 possibly being offered in the smaller size. Am I totally off - base? Maybe that was something else I'm thinking about.
--Bob
miller 210, w/spoolgn,.030 solid-core with 120cf C25 gas. Grinders, hf bender. speedgls 9002x helmet.
I wasn't down playing the passport just as a portable it doesn't have quite the oomph of the 210. I saw it in action at PRI and was impressed but I really like my mm210 and won't trade for the portability. 200 pounds is portable right!!! Portable enough, but not portable enough to be stolen!!!
Yup, the Passport is as close as you'll get. The next 210 will be the same size as today.
a-
OK, I'll bite.....what next MM210.....I can't, for the life of me think of what needs to be improved or changed on the MM210 (except the way a 8" spool fits ).....the IM210 for sure, but I for one like the MM210 the way it is thank you very much
Regards, George
Hobart Handler EZ125 - IMO the best 120V Flux Core only machine Miller Dynasty 200DX with cooler of my design, works for me
Wirefeed tracking would be nice!!!
I wound not trade my passport for a 210. I would trade it for 300 amp 32 volt inverter in somewhat the same type layout. I sure that it is on the drawing board some place. Just combine a Thermal LM 300 with a 8rc feeder. Those run on co2 wonderful and have a great tig/stick arc. It would weight about the same as a XMT but would be way cooler/handy.
George,
Based on info that Andy fed us in the past, I suspect sometime in the future the next version of the MM 210 might have a variable voltage control.
BTW, the current MM 210 isn t perfect, it is a very good unit, but it could be even better yet, if it had about at least 3 more voltage taps to choose from. Personally i 'd like to see one more tap that falls between the current tap #2 and #3.
Yep, WST is what we need, watch out if they have a recall on the Passport, they might be covertly installing WST on your machine just to see if you notice
Dan,
I don't mind if they upgrade the MM210, as long as they don't make it so much better that I have to trade up again BTW, whens that last time you checked your EMAIL ?
Regards, George
I'm thinking you guys have WST on the brain. It would be a nice plug in option, right?
George
Not to steal this thread, but what excatly is the trouble with the 8" spool? The reason I ask is that I was having a problem with my MM135 and 8" spools. They wouldn't stay on the peg and would wobble, resulting in feed problems. I solved it with a spacer. I also noticed that the 3045FC, which has the same drive set up, includes a spacer , pn-207305, for 8" spools.
Is that the prob you are having? Loose and wobbling spools? Spacer might help. Thought I'd pass it along. If not, just ignore the preceeding.
George
Don,
I never had a problem with an 8" spool on my MM175 (after I fixed it, see later in text), or any of the Handlers I have owned. On the MM210 the shaft is about 1/8" or so smaller in diameter than the hole in an 8" spool so it wobbles and sits further back than I would like. As I said it hasn't caused any problems so far and I am always looking for a deal on a 33# spool anyway. Just where on the shaft does the spacer fit, in front or back of the wire spool? When I had the MM175 I shortened the spring and used a nylon washer instead of the steel one and had no problems with that setup. As far as the WST, to me it was a minor flaw on an otherwise great welder, I sold it to get a MM210 (which I really wanted anyway), and I did get more than I payed for it new.
Regards, George
George
Ok, different prob. The spacer goes in between the spool and ring retainer. I am going to order one one day. Maybe when my cardboard one wears out.
George,
I am pretty sure I would notice that one!!! You would see it on ebay before you could say SP 135/175 plus. To tell you the truth I would just keep the Mutimaster 160 and get a small co2 bottle.
